hello everyone I’m new here, just started using litchi on iOS with my mini se (FCC).
I noticed litchi by default is set to 2.4GHz frequency band. Mini se in US. is 5.8Ghz should I change the settings?
It is actually a minor display issue.
We should not show the frequency band setting for mini se, we will remove it in next update.
For wifi drones, just select the channel you want, the correct frequency band (5.8 or 2.4) will be used according to the channel you select
