Hi
I’m using the latest version of litchi beta compatible with my mini 4 pro. However, I can’t get over 120m even though I set the maximum limit in 500m in the app. Is this a limitation of the app? It will be fixed?
thanks
Hi
thanks
Hey what is the setting in the DJI fly app, it may be overriding the litchi setting
Depending on your location, this may be due to restrictions built into the drone’s firmware. For example, in the EU the drone’s height above take-off is limited to 120m. Are you able to fly higher than 120m above take-off using DJI Fly?
EU Drone Altitude Limit (2024 Update)
In the EU, the maximum legal altitude for drone flights is 120 meters (394 ft) above ground level. This applies to most operations in the Open Category.
Always check your local airspace restrictions before flying.
Recent firmware updates (e.g., DJI Mini 4 Pro) enforce this limit automatically.
