I’m trying to control yaw and gimbal angle manually for a better look.
I use the wheel to ‘look’ down during the mission, why does my gimbal pitch always return to zero (level) as I reach the next waypoint even though it is set to “Default Gimbal Pitch Mode = Manual” in Mission Hub settings ?
Only in (each) waypoint.
The default setting in Mission Settings is used when creating a new waypoint.
So are “Cruising Speed”, “Photo Capture Interval”, and “Default Curve Size”.
