Message to Wes Baris
Hallo Wes,
Played with Cardinal Directions, works well.
Please add line to instructions:
 Set “Default Gimbal Pitch Mode” to “Focus POI”
Regards
Christi
The Cardinal Directions mission creator explicitly sets the gimbal mode for each waypoint to “Focus POI” which will override the default setting of the gimbal pitch mode. For example, my default setting for gimbal pitch mode is “Interpolate”. However, when I import a Cardinal Directions CSV file into the Mission Hub, each waypoint has the mode set to “Focus POI”.
You can verify the setting in the CSV file yourself. Open the CSV file in Excel and look at the “gimbalmode” column:
0=Manual
1=Focus POI
2=Interpolate
