Mavic 4 Pro camera specs
Does anyone have the actual camera sensor sizes for the Mavic 4 Pro. Need sensor and lens focal size. Any help will be appreciated. I know the Litchi app has the selection for each but it does not indicate the actual sizes and they are needed for other reasons. Thank you.
@Mike_M aren’t they on the dji site
Hi Martin. No, DJI has never specified any drones sensor sizes in their spec sheets. Don’t know why as they are needed for mapping as you know.
I have the same question but I have not seen the actual sensor sizes of the MAVIC 4 Pro in my usual sources. There is an article that does mention the sensor sizes of the M4P but I would consider them to be nominal sizes, not actual or active sizes.
https://www.dpreview.com/news/7871034403/dji-s-mavic-4-pro-drone-features-a-100mp-main-camera-and-improved-gimbal
Hi Wes. I’ve found similar specs myself on several different websites. I believe the 17.4mm width is correct which is just a tad bigger than the Mavic 3’s at 17.3mm and has the same height of 13mm. I’ve been told the focal length can be found in the photos meta data but if it is there I don’t have the Mavic 4 to check. Your more knowledgeable then me with this stuff so maybe you would know if the focal length is in the meta data. I don’t know why DJI does not specify these sizes in their drones spec sheets. With all the technology and information out there these days you would think this information would be readably available.
