Matrice 4 Enterprise
I have a Matrice 4 Enterprise and started using Litchi Pilot for waypoint missions. So far it works great. I tried using the regular Litchi app for other things like FPV and I can’t even get the camera to connect. All other apps on the remote are force closed. The litchi app will start, and my location is correct on the map, but the camera will just not connect. Any help or suggestions would be appreciated.
Enterprise drones are not officially supported.
Some enterprise drones are officially supported in Litchi Pilot Beta but not in Litchi for DJI drones.
With that being said, we don’t test all Enterprise drones (that would be very costly!). We can confirm full compatibility with the Mavic 3 Enterprise series (M3E and M3T were both tested).
For the Matrice 4 Enterprise, we did not test it, but normally it should work fine.
I assume you have video working fine in DJI Pilot 2?
Are you using the latest Litchi Pilot beta build (595)?
If the problem persists, please post a screenshot/video of the main screen of the app
Thank you for the reply, to answer your questions.
  1. Yes everything is working as it should on DJI Pilot 2
  2. I am using the latest Litchi Pilot beta but my issue is with the standard Litchi app.
  3. I will be testing it on my Mavic 3 E today and will post screen shots after I test them out.
Again, thank you for the input and I will let you know my findings.
Newer drone models (anything released after Mini 3/Mavic 3 Enterprise) are only compatible with Litchi Pilot beta. The old app is for older drone models only (Help - Litchi)
