Anyone working with Matrice 4 series and importing KMZ files into DJI pilot 2 ?
Looks like I can not get waypoints with POI’s working using KMZ files and pilot 2 app..
Welcome to the forum.
I have moved your post into its own thread because it wasn’t clear that it belonged where it was.
While I do not have a Matrice 4, I have never seen a Pilot 2 (or a DJI Flight Hub 2) mission that has POIs. I do not see how to create them in Flight Hub 2. Are you sure the Matrice 4 supports them?
When converting Litchi Missions with POIs to a mission compatible with an enterprise drone, I simply use the computed headings and gimbal pitches in the converted flight. I’m pretty sure the KMZ export from Litchi’s Mission Hub does the same thing. The POIs won’t be converted but the corresponding headings will.
DJI Pilot 2 does support one POI (max). We forgot about that as we were testing mostly in Flight Hub which does not support POIs at all, go figure!
We will fix this bug shortly.
Thank you for replying and possibly fixing it !
I have tested several option with path, heading etc but the drone is also not pointing into the poi direction. It does however works fine in the simulation (once I found the correct selections).
Using Litchi Pilot did fine btw. It shows the poi’s on screen and the drone follows directions as planned. To expand on this, it would be great if you can tweak the poi position during waypoint flight ![]()
Best regards,
Should be fixed now.
Max one POI is supported in DJI Pilot 2.
Currently we don’t support moving POIs during the flight in Litchi Pilot
