Using my Mavic 2 Pro, I decided to try my hand at drone mapping, with the intent of “stitching” the hundreds of pictures taken by the drone is it flew a lawnmower pattern, using Web ODM, to create 2D and later 3D maps of an area.
Starting with the free utility to create the flight path called ancient land at this website https://ancient.land I drew a polygon around the area to be mapped, and set the altitude at 168 feet AGL, with the overlap at 70%.
Then I watched as over 200 waypoints materialized on my screen in the classic lawnmower pattern. Exporting that mapping mission file to Litchi Mission Hub was easy, as was setting the camera to take a still picture every 5 seconds.
Then came the moment of liftoff for the mapping mission. I decided to try out my Samsung tablet so that I could use the Android version of Litchi for the first time, after using my iPad’s IOS version of Litchi for hundreds of previous Litchi missions.
As the drone loaded up the mission before takeoff, I saw an on-screen alert warning that the drone would “interrupt” the mapping mission when the 99th waypoint was reached, so that the remainder of the mission, totalling about 221 waypoints, would load. Disconcertingly, that on-screen message also stated that the drone MUST be in signal range when that mapping mission interruption occurred.
To ensure that there was NO break in signal, I moved closer to the area I was mapping, until the drone was within line of sight. Before I was able to approach within line of sight of the drone, the signal disconnected when the drone was less than 200 yards away, as compared with the Litchi screen only starting to glitch at half a mile away when I used the IOS version of Litchi on my iPad.
I became even more nervous when I was able to see the drone flying the grid mission less than 100 yards out, because the red “Disconnected” banner STILL showed on the Android Litchi version’s screen. At that point, I decided to end the experiment by switching to sport mode, and landing the drone after it had completed less than 10% of the mapping mission’s projected elapsed time of 35 minutes, which the Mavic 2 Pro would have flown under the power of an extra-range Ali Express non-DJI battery.
Before I set my Android Samsung tablet aside and revert back to using my iPad’s IOS version of Litchi for another trial run of the mapping mission, I would like to ask a question about what I can expect the drone to do when it reaches the 100th waypoint of that mapping mission.
Since Litchi issued a warning that the drone MUST be in signal range of my controller when there is a break in the mapping mission, would I be correct in assuming that I will be required to initiate the download of the remaining waypoints once the drone reaches the 99th waypoint? What exactly will occur at the 99th waypoint? Will the drone go into a hover and present me with a prompt to upload the next 100 waypoints? Or will the drone Return to Home before prompting me to upload the next 100 waypoints?
My other question is why the signal range of my controller is so much shorter when I use my new Samsung Android tablet, as opposed to the far greater signal reach I became accustomed to seeing when I used my iPad for drone flights with Litchi’s IOS version. Is it possible that the Android version of Litchi attenuates the signal of the RC controller in some way?
