Hello,
since I have not found a way to do it here I am asking for your help.
How can I replace the default satellite view with a different one or a map (like OSM)?
or
How can I add as a reference layer a KML? In other words, I do not want to make waypoints out of KML, but rather to add them manually and have the KML only as a refference.
The KML represents a freeway that is building up and sattelite images do not have newer images. When I import the KML… there are like thousands of waypoints added, impossible to delete them because it slows down the editor that makes it impossible to use.
I know that I can go and do it in a different map… but it would have been much easier / faster if I could do it from within the mission hub.
Thanks.
