The follow mode itself has some delay. In magic leash mode, it is a little more. It doesn’t bother me. The drone keeps up with the pedestrian.
If you fly behind a car, you can get very unexpected results.
Glad you are happy with way things are.
It still seems to me that requirements, along with the functionality’s limitations should be fully disclosed - as well as “what happens if” behaviors that are driven by the apps’ engineering.
Take care….
If the drone loses an object, it will freeze until the connection is restored. Rc does work. If it loses rc, then rth will work.
I want to notice that many people have problems with the activetrack function, when the drone starts randomly jumping from side to side, and yet this is not described in the manual.
I would add to the application, and already wrote about it in support, so that the active magic leash pin is constantly tracked in the litchi application on the map. At the moment it doesn’t work, I only see the first dot of the second mobile device.
