It’s been a long time since use of Mission Hub and some how it knew my new email! . Mission Hub shows my credentials and a recorded mission but load mission, Litchi on iPhone shows none. Must I log in on iPhone? If so , how ? I see no way to verify Litchi version or verify my identity , only clear waypoints.
You must use the same login credentials on both the Mission Hub and your iPhone in order to share missions between the two. In the Litchi app on your iPhone, select the main menu from the upper-left corner of the display and then scroll down to where it says “Log In”.
I didn’t realize top left menu is scrollable to LOG IN
thanks
