Litchi Waypoint Mission DMS Coordinates v. DDM Coordinates
I have learned how to create a waypoint mission and run it virtually on Google Earth Pro, etc.
Now, wanting to fine-tune a mission’s waypoints, I want/need to tweak them numerically at each waypoint in the Litchi Mission Hub.
My issue is that the Litchi app on an iPhone shows Lat/Long coordinates in DMS (Decimal, Minute, Second format), but the Litchi Mission Hub uses DDM coordinates (Decimal Minute Coordinates).
First, I don’t understand why each uses a different coordinate method since these tasks are closely related and are both used for the same end goal using the Litchi app for Waypoint Missions.
Second, if that is the reality of the situation, is there a way to change the coordinate TYPE in the Litchi Mission Hub from DDM to DMS?
Absent that, every waypoint tweak needs to be manually converted from DMS to DDM before entering it manually (tweaking it) at each waypoint in a waypoint mission in the Litchi Mission Hub.
That is, I can carefully fly a mission, stop at evey waypoint to get an EXACT waypoint coordinate in DMS format off the iPhone Litchi app, but then have to manually convert each of those coordinates into DDM format before tweaking the coordinate in each mission waypont in the Litchi Mssion Hub, before “saving” again, etc.
I have spent a couple of hours trying to find the answer without bothering you folks here in the forum, but I have been unsuccessful, so I am giving up and asking.
The Mission Hub show them using decimal format just like Google Maps. You cannot change that. However, in the Litchi app, you can go into settings and change the GPS Coordinate Format.
DUH! Incredible. I thought I had looked into that.
Thanks so much Wes Barris !!!
