Pardon my ignorance, but is there a user manual for the Litchi Pilot beta? I can’t seem to find one. I can’t find a lot of necessary settings, like focus, video resolution, etc.
best, geb
best, geb
If you can’t find something in the Litchi Pilot Beta app, then most likely it’s not yet implemented.
Thanks! Is there a workaround for setting the focus?
Settings that are stored in the drone itself remain there unchanged regardless what app you use, until you change them again with whatever app you use.
Use the DJI app to set the focus, then switch to Litchi Pilot.
Ah I see, thanks!
The focus can be set in Litchi Pilot via tap to focus. Manual focus will be added at a later stage.
Video resolution can be set in the DJI App. We will add that also at a later stage
