Litchi Pilot recording in 10bit
Hi all
I found out that my videos recorded with Litchi Pilot on Mini 3P have 10bit color depth, which causes the colors to be washed out when watching on the TV, while videos recorded with DJI Fly have 8bit color depth and are looking fine.
I can’t find this setting to be changed in Litchi Pilot, can you help?
It sounds like you have D-cinelike enabled in DJI Fly?
So there’s no settings for video in LItchi Pilot, only DJI Fly can be used to set up the drone? I’ll check, thank you for the hint.
Start up Dji Fly app change the settings kill DJI rhen start Litchi
Problem solved, indeed, the set-up has to be done in DJI Fly, Litchi takes over the settings.
Thank you all.
