Litchi Pilot on Air 2S
I downloaded Litchi Pilot today on my Samsung S22, I ask: can I use it on the AIR 2S?
No. Litchi Pilot is compatible with the Mini 3. The standard Litchi app is compatible with the Air 2s.
Thanks for the reply, I’ll wait for an update for Air2S so I can try it out. I already have Litchi and I’ve been using it on the Air 2S (I’ve had it on the Mavic Mini since 2019, then the Mini 2 in 2021 and after 2023 on the Air 2S and it’s certainly the best flight app out there). Have a good flight and take care.
What update are you waiting for? The new Litchi Pilot app will never be compatible with the Air 2s (if that is what you mean).
Litchi pilot is a version of litchi based on DJI’s MSDK 5, and is designed for the mini3, the A2S uses the original version of Litchi which is based on DJI’s MSDK4
Clarified, I will delete it, since it will not be available for Air 2S, thanks for the information, you can close this topic, have good flights, take care.
I have been using litchi on my Air2s for well over a year or two. It works just fine with that drone.
As others have posted here, you are using the original Litchi app, which does work fine with the Air2S.
The original poster was asking about the newer Litchi Pilot app, developed for the MSDK v5. It isn’t compatible with the Air2S.
