LITCHI PILOT change camera resolution DJI Mini 3
Hello I have a DJI Mini 3 drone wich i use to do a little bit of photogrammetry.
I am not able though to switch camera resolution between 12MPx and 48MPx from the litchi pilot app.
In fact, the first time it opened it was 48MPx, i changed the mode to timed photos and it went to 12MPx, which is fine because I think 48 MPx is only available in “single shot mode”; Then for some reason, I have not been able to change the single shot mode back to 48 MPx ever since.
Could someone explain me why ? Is it a bug of the app.
Thank you.
The issue is due to a bug with the Mini 3 (standard only, pro works fine) in the latest DJI SDK, which we have reported. Normal photo mode cannot be set in the latest Litchi Pilot beta build with the Mini 3, and this bug also prevents switching camera modes. However, by switching to AEB or Interval mode in the DJI app, you can then toggle between photo and video modes in Litchi Pilot.
Alternatively, you can also install the previous Litchi Pilot beta build by downloading it here
Thank you, I also thought it was a bug.
I was already using litchi pilot beta, but the problem still persists.
I have no problem switching between camera mode and video though.
Install the previous beta build 380 by downloading it here
This will solve your problem while you wait for the SDK fix.
