I have used the beta litchi pilot app on my android with my DJI mini 4 pro with no problem.
Today I tried to update and I get failed to validate license.
I own litchi for DJI drones, but do not believe it works with mini 4 pro
Any ideas how to get around this error. I really like the app
Try two things:
- Make sure you are logged into your Litchi account in the Litchi Pilot app.
- See if there is a “Check and Sync License” option in the Litchi Pilot app settings.
I have the same issue and you cannot even get the app to load to check settings anymore
Today, january 29, Ive tried to use Litchi Pilot beta 595 but send me license error. Message is “License check failed”. Litchi for Dji drones works fine but otero app is failing. Update is not working.
Connect to internet to validate your license (currently free for the beta).
Same Problem here. Installed the latest beta version (595) of Litchi Pilot, connected to the internet, but still “Licence check failed”. I don’t even have access to Pilot Litchi to change any settings. Uninstalling the app and reinstalling didn’t help.
This usually happens when the app can’t reach required services, even if your internet seems fine.
It needs access to Google DNS (8.8.8.8 which is what we use to tell wether or not you have internet access) and our servers (https://parse.litchiapi.com), and some networks (VPNs, corporate Wi-Fi, certain routers) can block one or both.
Try:
• Switching to a different Wi-Fi or a mobile hotspot
• Disabling any VPN or firewall temporarily
Got it. Thank you. It was just a Wifi problem. I changed the wifi spot and it worked.
same thing as happening to me if I start my drone start to controller and then plug the cable into my tablet the Apple will come up and run, but I cannot open the let you pile app. It says license fail. I’ve sent numerous emails to let you and I still haven’t got the problem figured out got everything they’ve told me but the way I can get it to start. The app is like I mentioned in the first of the message.
Have you tried:
- Re-installing the Litchi Pilot app?
- Making sure you have a working connection to the internet?
- Making sure you are logged in with your Litchi credentials?
i hav done all these things. Also talked to vc technologies and they verified my license is valid.
No one seems to have an answer as of yet.
Also when i tried to update app it goes to the license fail. thanks for your reply
Latest beta build 650 should help with this
