I went to use Litchi for the first time in a couple of months this morning and when I launched the app on my phone it came up with message that I was logged out and I needed to sync Litchi with app store. I saw no way to do the sync so I uninstalled the app and now the app store wants me pay again to download the app. I also installed Litchi on my android tablet for the larger view so I logged out on the tablet but still no luck on my phone which I use with my drone. I am able to log in and out of Litchi on my tablet and leave it logged out when I use the phone. This has always worked fine in the past. How do I get around this?
All you needed to do is to log in using the second from the bottom item in the main menu.
In Litchi Settings you will find this item:
Check and Sync License: Tap to synchronize your Litchi app’s paid license with your Litchi account. This will unlock additional features in Mission Hub.
You have to be logged into the app store using the same credentials as were used when you originally paid for Litchi. The message above suggests you were not using the same credentials.
Logging out on your tablet is not necessary. You can be logged into your Litchi account on more than one device at a time.
To re-download the app on your phone, you will need to log into the app store with the same credentials used when you purchased the app.
You have my issue 100% correct. I have a second app store account I use for my home IOT devices and I was logged into that so my Litchi purchase was not there and I never noticed which account I was using.
Thanks for the quick response.
Larry
