Litchi Mission Utilities Litchi to DJI Fly Waypoint Mission Converter
Hello,
I have produced a 2 camera action waypoint mission in Litchi Mission Hub (Stay For 2 seconds and Take Photo), however, attempting to produce a DJI Fly kmz file it states that for waypoint 2 and the other dual action waypoints ‘Waypoint 2 has 2 camera actions defined. DJI Fly will only perform one action per waypoint’.
I am presuming that this is a constraint of the conversion process and that only a single action eg Take Photo can be used? If so I will need to adapt the process to include a Hover time for each waypoint in DJI Fly.
Many thanks
It is neither a constraint of the conversion process nor of the WPML language. Both can handle multiple actions performed sequentially. The converter will encode all of the actions into the KMZ file. However, I have been told that DJI Fly only performs one action per waypoints. I can’t test this myself because I do not have a DJI Fly waypoint drone.
If you find a way to make a DJI Fly waypoint drone hover and then capture a photo at a waypoint, I would be interested to hear about it and would like to see the KMZ file.
Hi Wes,
Many thanks for the response. Having tried to upload the .kmz file to DJI Fly post .csv conversion which includes 2 camera actions it is evident that DJI Fly does recognise the Stay For/Hover command as well as Take Photo. The Stay For/Hover period must be set to >=1 sec or 1000 in Litchi speak or it will not work. What’s the most convenient way to send you the .kmz file?
Thanks
Would you clarify. Are you saying when flying a converted mission, the drone does hover and then takes a photo? That is what is configured in the converted KMZ file but I’ve been told the drone does not perform both actions.
You may contact me through my web site if you want to share a file with me.
I noticed that DJI Fly would take a photo then pause for the time interval (3 sec I’m my case) not what I wanted. My work around was to program 2 waypoints at the same physical location the first had the pause and the second took the photo. This worked for me but it was a pain - I’ll try in Litchi pilot if I have similar issues.
