Hello,
This is to let you know that, using the extremely helpful and precious program defined by Wes Barris, to convert a Litchi Mission to a DJI Waypoint Mission I have got the following error: Notice: Undefined offset: 0 in /home/wesbarri/litchiutilities.com/public_html/litchiToDjiKmz.php on line 593
The message is repeated on several lines. Unfortunately, although the conversion process ends-up apparently with no further issues, when I try to run the mission from the RC2 controlled in the field, the mission starts but in facts the drone keeps hovering and does not follow the waypoints/POIs, no error message is provided.
I have tried to understand the problem and that is likely related to the “Above Ground” CheckBox as defined for each waypoint in Litchi: When the option on each waypoint is checked then no undefined offset error is given and the coversion goes fine. When the Above Ground checkbox is unchecked and the height for each waypoint is defined in absolute values (i.e. NO above grounds height) then I get the error message again and the mission is not usable in the DJI app.
Any thoughts to confirm my observations and ideas on how to fix this would be greatly appreciated !
Diego
