Are you creating missions using the Mission Hub and not seeing them on your phone? Or, are you creating a mission on your phone and not seeing them in the Mission Hub?
If you are creating them on your phone and not seeing them on the Mission Hub you will need to enable this option in Litchi settings:
Sync Local Missions: When enabled, and provided you are logged in to your Litchi account, missions created on the device will be synced to the cloud so you can access them on other devices.
Otherwise there are only two things that are necessary for missions to sync successfully between the Mission Hub and your phone:
You must be logged in to both the Mission Hub and Litchi on your phone using the same account.
Both Mission Hub and your phone must have network access.
Litchi mission hub not syncing with iPhone 8 - I have same problem with new iPhone 8 plus (no SIM card just WI-FI tablet).
Litchi mission hub will synch fine with my old iPhone 8 standard.
What is the deal with new phone.
Help.
Vince
If it uses Wifi to connect and it works well, then it has to be a login/password issue.
Have you checked the General settings?
’ Sync Local Missions :’ When enabled, and provided you are logged in to your Litchi account, missions created on the device will be synced to the cloud so you can access them on other devices.
SOLVED
I needed to link my new Iphone 8+ to iCloud properly and now works well to pick up waypoint missions created on Litchi Hub on my computer.
Thanks for all help,
Vince
