Litchi Hub Vs. Litchi iOS missions not sync'ing
I know this is similar to other posts. Missions created via the web are not appearing in my iOS Litchi app and visa-versa.
Yes, I am using the same e-mail address and password on both platforms.
Yes, I’ve logged off-and-on again on both platforms.
Yes, I have “Sync Local Missions” enabled.
As a test, I updated my account name on one platform and when I logged back in on the other, the new name appeared. So, I think that part at least is working.
What else is there to try? Thanks.
-Greg
You seem to have tried all of the usual remedies for this problem. I assume that syncing was working at one time for you. What has changed since then?
I only use iPads so I just tired to see if a new mission would Sync. I created a couple new missions, one map and one path and they both synced in the Litchi mobile app. Only thing I can think of is the Litchi mobile app displays them alphabetically. So whether it’s in a folder or not their all alphabetical. Are you sure it’s not under one of your folders ?
I also just tried the Old Litchi mission hub and they sync as well.
Nope. I’m a brand new user. Installed it for the first time a day ago. Created a couple missions on the laptop and now I want to fly them. Not off to a good start.
There is an “old” mission hub?
I am an iOS user too. I use the original Litchi app on and iPhone and an iPad. When logged into both the hub and the app with the same Litchi credentials, it just works.
Is there anything about your setup that you are not telling us? If not, you might want to email support at support@flylitchi.com
May not help but have you tried syncing the license to see if there are any notices or errors.
Several times. No errors.
Laptop is running Ununtu and Chromium browser. Phone is an 11 Pro Max running iOS 26.2.2.
:man_shrugging:
Nuked everything and started over. Working this time. Weird. Thanks all who tried to help.
Anyway, keep the drones in the middle of the air!
—Greg
That’s technology for you. Sometimes with no rhyme or reason things freak out. Enjoy.
