Hello… Can anyone tell me if one day we will have the Litchi App working with PH4PRO+V2.0 With a Built-in Screen?
Thanks in advance for the information.
Jose Carlos
Balneario Camboriu, Brazil.
We had one user tell us it worked for him to do the following:
Use a cable and connect it to the usb and the mini usb on the controller.
Open Litchi
Shut down all running DJi apps
In settings activate Debugger and attribute inspections.
Then return to Litchi the and connection to the drone will be there. If not, then close debugger and open it again together with the attribute inspection.
As for official support, most likely will never happen as DJI never made it work properly with SDK apps.
It is recommended to use a remote controller without the DJI built in screen then you can use Litchi
Dear @vico, thank you for your reply.
I’ve tried this procedure several times and it doesn’t work. It even works on the PH4PRO+ V1 but on the V2 (RC GL300K) they discarded Litchi. It’s unfortunate.
Thanks again for your attention.
Jose Carlos
Hi @ZAER360-BR
It is actually working for me with a RC GL300K, and it is perhaps my solution mentioned, but something is missing, so try this:
Use a cable and connect it to the usb and the mini usb on the +controller.
Open Litchi
shot down all running DJi apps
Then return to Litchi and connection to the drone will be there. If not, then close debugger and open it again together with the attribute inspection.
It work for me every time, so I hope you can work it out too
