导出时出现这个提示 “License verification required to continue” 怎么解决?
I am assuming that you are trying to export a CSV file from Litchi’s Mission Hub. Are you logged in with your Litchi credentials?
是的,我使用的Litchi credentials登录的。当我导出CSV时。
The obvious question is: “Do you have a valid Litchi license?” Did you buy the app for either an Android or IOS device? If you did not, you would receive the “License verification” message. If you do have a valid Litchi license for the Litchi app, log into that app using your Litchi credentials and then go to “Settings” and select “Check and sync license”. Then go back to the Mission Hub and try again.
