I have created very large waypoint missions that I have imported into DJI Fly (>500 points) that do not always crash, however my Mavic does not continue past the first waypoint as if there is no course to follow. Has anyone had this issue? I tried to create a smaller flight plan with the same settings and it was able to follow course. If anyone has experience with the waypoint threshold, let me know!
There have been reports of large missions that fail to load or even crash DJI Fly. However, I have not heard of what you describe. It isn’t the number of waypoints that is the limiting factor. Instead, it is more closely related to the size (in KB) of the KMZ file and the memory available in the device running DJI Fly.
The WPML language is very verbose and missions with larger numbers of waypoints or large numbers of waypoint actions cause the KMZ file to be much larger. I know of those who have successfully executed 900+ waypoint missions using an RC Pro. I also know of those attempting to run a 100 waypoint mission with camera actions that fails on an RC2.
I’m curious what device you are using. RC-N1 with a phone or table, RC, or RC Pro?
Thanks for the reply. I am using an RC Pro. Do you know if anyone has had this “pause at waypoint 1” issue regardless of the file size or flight plan? I am using the orthomosaic settings with a photo camera action at each waypoint.
I had this same issue with my M3C and RC Pro (now RC Plus). My workaround is to have the mission be “video” not photo, then manually start the photo timelapse function on the drone. I’ve been able to do very large areas this way, where I couldn’t before.
