Arbeite mit dem RC Pro und isntalliertem Litchi. Die letzen Flugdaten (sichtbar auf Airdata) sind vom 9. März 2023. Alle Flüge nach dem 9. März haben keine Daten mehr erzeugt. Versuche ich innerhalb Litchi auf dem RC Pro die Daten mit AIirdata zu synchronisieren, so wird gemeldt: Keine Daten vorhanden.
Have now just the data from 15 March 2023 in my log files
seen. I.e. it took 5 days for the data to arrive on Airdata?
It seems that something is working but not so very fast? Does it need any trigger to send the data?
Token: [token removed by admin]
I am at the drone flights today and will inform you.
Other chapter
Litchi crashed 3x in a row, immediately after power up. Is there log files you need. I stop DJI Fly each time before starting Litchis. Is this correct so and necessary?
As far as I know the Amazon version 4.26.2-a is stable.
Like I wrote before:
You have to FORCE CLOSE DJI Fly after stopping it before starting Litchi.
There must be some method on the RC Pro to get an overview of all apps stopped but still running in the background.
On an android smartphone/tablet it’s the bottom-left button next to the home button (3 vertical lines).
Here you tap the ‘Close All’ button/icon (or a large ‘X’).
