Is there a way to see heading in degrees in 'Toward Next Waypoint' mode in app?
If I use the Mission Hub, I can see the heading of the current waypoint in degrees by clicking on it and looking at the ‘Heading’ slider.
Is there a way to see it in the app when ‘Heading Mode’ is set to ‘Toward Next Waypoint’? If I click on the waypoint in the app, there is no indication of the heading between waypoints.
I want to be able to have the drone pointing ninety degrees from the heading it is flying between waypoints.
I’m using the Android version of the app.
No, there is not. Both on iOS and Android.
I have a work-around.
I set my waypoints with the heading mode set to ‘Toward Next Waypoint’ and and when I’m finished I then set the heading mode to ‘Waypoint Defined’.
I can then check any flight headings I want the drone to be facing a ninety degree angle from and write the current angles down. Then I can add or subtract the ninety degrees from those current headings.
No, that doesn’t work. I think it only worked the first time because I was mucking around with one mission. It looks like the headings default to 360 degrees on a new, clean mission, or the last heading of an edited mission. :frowning:
