Initial look at the Mini 4 Pro with Litchi Pilot
Having got my hands on the rc-n3 and a quick FW update i have the app working ok,
but i tried the auto take off and my Mini 4 took off then just shot backwards resulting in thankfully no damage that i can see.
Any idea though why the camera settings are stuck on the screen, (AFC WB ISO etc etc) i cant find a way to remove them.
It sounds to me like the drone needs to be calibrated in DJI Fly.
Exposure settings cannot be hidden, but you can double tap on the video stream to remove all UI elements
Hi Vico
sadly my Mini 4 has developed and issue and has to go back to DJI, nothing to do with Litchi, seems to be a downward sensor issue. pity as i really wanted to test Litchi.
Will the MIni 4 now just use the pilot app or will it get moved over to the main litchi app once testing is done?
Litchi Pilot and the original Litchi app are based on different SDKs.
The Mini 4 (and all models based on MSDKv5) will always use Litchi Pilot.
Hi, I’m new to the litchi ecosystem, and wondering if there is a way to use litchi pilot with my mini 4 pro if I only have the rc2? I downloaded the pilot apk, turned on both the drone and the rc2. I open the litchi pilot app, but I can’t get past the “drone not connected”. Can’t find a tutorial how to connect, or if it’s even possible using the rc2. Thanks in advance…
RC2 is not supported. Only RC-N2 and RC-N3 are supported with Mini 4 Pro
how did you download the app? and then install it
