I’m trying to run a mapping mission using the Area Mapping option in the new Litchi hub.
I selected a start point, drew a mapping area, and set some conditions. Then I tried flying the flight path generated.
The system generates a flight path with enough photos to cover the area, but only some of the “take photo” actions force the drone to slow down, with some photos shot while moving.
Besides this, halfway through the mission, for some reason, the gimbal angle switches from -90 to -83 and stays there, despite the setting being “locked. -90”.
So, two things: 1) How can I manually assign a “stay at” command to each waypoint in the Litchi hub? 2) How can I make sure that the gimbal angle will be -90 for all points?
edit: Now I see it’s possible to do all this in the original “mission planner”, but not in the new “hub”.
