I want to plan sessions for my forest, but it hard to find out were i am, seeing trees only without having landmarks. i use for my daily work my map with the custom maps app. after importing a picture i create a grafik kmz file showing my position in my forest section…
is it possible to import my kmz for planning a session instead of google maps?
see sample below
If you start a new route and use “Import” there is option for KML, can you export your Google Earth data that way and then import?
PS I just tried KMZ and it doesn’t like that very much!
Hi George
many thanks. i will try and report if it works
Kmz is just a zipped KML file
Unzip it and then you can try to import the KML
However please keep in mind Mission Hub only supports a limited number of kml features
