Import file .mis
Hi everyone,
I can’t import missions with the .mis extension created with thopos, why?
It’s likely a proprietary file format that isn’t compatible with other flight planning/ control apps.
If you have the option to export a .csv file from the other app, you might be able to import it into Litchi. Not sure, but it’s worth a try.
I’ve always imported .mis files from missions created with thopos, but with the new version of litchi, this is no longer possible.
I found the solution by renaming the files with the .lchm extension.
Thanks
