I can´t change the direction of the waypoint
Hi!
Please i need help. I usuly use the the “waypoint” feature too set a mission, but now i have a problem with the “heading”. I cant edit the direction of the drone. I tried to do a new mission where the drone will fly around a building but it did not work because I could not edit the direction in the app.
You can only change the heading of the drone (in Waypoint Settings) when in Mission Settings ‘Heading Mode’ is set to ‘Custom(WD)’.
Yes it did work, thank u very much.
