Today, I have been testing the track feature. I noticed, like many others, that it wouldn’t work properly. After some more testing, I finally got it to work. Here’s how I did it: 1: Joystick speed limiter should be at 100%; 2: The aircraft should be about 2 meters above the tracked object; 3: Make sure there is enough contrast between the background and the tracked object; 4: Make sure there isn’t anything that the drone may crash into (it helps to have a finger resting on the RTH/Pause button ); 5: Start!
I hope this helps!
