How to get distance between waypoints to display in new version?
The old version used to display the distance between waypoints which is critical for keeping the correct distance between flight lines. The new version does not display the distance.
Select a waypoint. Then the distance to the adjacent waypoints will be displayed.
I used to be able to see it when dragging a new waypoint prior to setting it. For example, if I need to keep 90’ between my waypoints, I was able to drag the point until I hit that distance. That is no longer an option?
Haven’t you tried it? Do this:
  1. Click (and release) on a waypoint. The distance to the adjacent waypoints will appear.
  2. Click a second time and drag. The distance to adjacent waypoints will update while you drag.
Works like a charm, thank you for the help-
