How to calibrate compass?
User guide states; " Calibrate Compass : Tap to start calibration procedure. The aircraft LEDs will turn solid yellow and you can then start the “calibration dance”."
When I start Calibrate Compass, voice instruction always says " hold the aircraft horizontally and rotate it 360 degrees", but after performing that it often does NOT give the voice command for “hold vertically…”.
What am I missing? What should I be looking for? on the drone? on the app?
Cheers
Litchi v4.26.2-g
Google Pixel 6
DJI Mini 2
Read page 48 of your drone user manual and pay special attention to the aircraft status indicator.
Most likely the first step was not succesful.
