After thousands of miles of Litchi waypoint missions flown without incident, the law of probabilities finally caught up with me and the result was a Mavic Pro Platinum engaging some high-tension electric cables in a life-and-death duel, with predictable results.
I had been testing the newly released extended-range battery for the Mavic 1 Pro and Pro Platinum, and the drone was 3 miles from home after traversing the skies above a huge palm tree plantation and a couple of swamps when it sent me an RTH alert.
Other users of this battery had recommended disabling smart RTH prior to takeoff, yet I was reluctant to cut that safety tether, and so foolishly opted to cancel RTH on the fly, banking on the premise that the drone would then complete the 12-mile round trip waypoint sequence without incident after my initial RTH cancellation.
Unexpectedly signal loss occurred at the precise moment when I canceled RTH, and I now surmise that the 240-foot RTH altitude I’d pre-set was either not sufficient to clear the high-tension cables or was inexplicably ignored by the drone, such that it went into a dive at the worst possible moment. and flew backward into the cables, at which point gravity exerted its influence without mercy.
Hopped in the Jeep and sped to the crime scene as indicated on my Litchi map screen, and after a few minutes of stumbling about in a corn farm, located the Mavic Pro Platinum where it had landed in the soft grass. The massive after-market battery had been ejected on impact and showed clear signs of abrasion where it was scuffed by the power line, while the battery housing has a minor dent in it. Tested the battery and it does power up the drone normally.
After my official mourning period has been observed, I will conduct a test of this drone, whose rear panel now sports a significant structural crack which may or may not mean the drone has breathed its last. Amazingly the camera of the drone appears intact. The fact that the drone was flying backward at the moment of impact is the reason why that camera was spared any visible damage.
I’ll take a few post-mortem photographs later today and add them to this thread. If I were to cite a lesson learned from this debacle, it would be that anyone who has installed a larger-than-stock battery in their Mavic 1 Pro or Mavic Pro Platinum should just go ahead and cancel smart RTH before takeoff IF they are intent on exploring the new range envelope made possible by that larger battery. Better risk landing with 15% battery than risk the drone adopting unpredictable RTH altitudes.
