New guy here and I need some help. I’m trying to set up some missions to do detailed roofing inspections and I keep getting a parsing error when I try to import the kml file into litchi. What am I doing wrong?
Without seeing the file you are trying to import, no one will be able to tell. You will need to share the file so we can examine it.
Thanks. I think I figured out the problem. I had some of my waypoints too close together.
The minimum distance between waypoints is 2 feet or 0.6 meters.
