I recently purchased the iOS app to be able to use waypoints with my Mini 2. I saw the tutorial on using Google Earth Pro and thought it’d be perfect for me. I followed the tutorial exactly, but when I import the KLM file to my Missions I get, “new - 1.800054447679253e+30m. | NaNs” with a view of the entire earth multiple times and yellow lines going everywhere.
To say I’m disappointed and frustrated is an understatement.
How can I fix this?
Thanks,
Paul
It is difficult to tell from your description but you must be doing something wrong. This feature does work (I just tested it).
- In Google Earth Pro select a series of “Add Placemark” that will represent your waypoints
- In Google Earth Pro select the folder containing these placemarks and choose “Save Place As…”
- In Google Earth Pro save as a kml file (not kmz)
- In Litchi’s Mission Hub import this kml file while selecting “Treat Views as Waypoints”
You will now see a waypoint mission in the Mission Hub.
If you are indeed following these steps, you will need to provide more detail on the steps you are taking.
