Quite often here it’s so rural, there’s just no way you can do multiple GCP spread out over an area and then survey the area.
Instead I was thinking - one does an area survey 300x300m for instance and then in that area (grassland, farmland, etc) I go to several locations where I put a helipad on the ground - with a nice X in the center..
I take off at that location and fly a 20x20m area at 40m elevation around the x and the x I can survey with the RTK rover.
I do that for a couple of locations and I got my whole 300x300m area properly aligned within a few cm accuracy.
Is it possible to create such a plan inside the mobile app?
basically:
Take off from this location up to x meter and then fly a square around that take-off location of y length for the sides of the square and then make a photo every z meter along the flightpath
Such a functionality would be a real life-saver for rural areas.
