wonder where to format and setup SSD in Litchi/Crystalsky Monitor/Cendence Controller on Inspire 2
Any format/setup etc would likely be done using the DJi Go 4 app. Litchi (and others) will just pull the available information from the aircraft.
Hi Sam_G,
… thank you, I had already thought of something like that, after I had not found any other solution myself. But you never know. But as I was able to find out in the meantime, the Z5/Z7 camera at least records in the DJI app configured format. Not quite elegant, but adequate.
Kind regards
Ernst
I dont know about your version of Litchi, but my IOS version has a ‘Format SD Card’ option in the Camera settings.
Open Camera Settings and scroll down (or slide up, as the case may be)
I also have this function in the latest Android version for Crystalsky Monitor, unfortunately no specific options for the SSD and the desired recording format other than for the SD card as you mentioned.
Kind regards
Ernst
