First flight using Litchi for IOS and Mini SE
I’ve been waiting forever to retire my Spark, but never could because my SE didn’t work with Litchi….until now! Im happy to report that the new update works perfectly with my MiniSE. I tested the following modes in all three remote modes: FPV, VR, Waypoint, and Orbit. Everything performed perfectly and as expected.
Ill continue to test and let you know if I find any issues, but as of end of mission 1…results at 100/100.
Here’s a couple pics from a golf course several miles away from me using waypoint mode.
Thank you for your feedback David.
David, you said this was from several miles away. Did your controller lose connectivity with the Mini SE at that distance? If connectivity was lost, did the SE still follow the waypoint mission and automatically return to home?
DJI Fly drones will all end the mission when signal is lost.
The target was 1 mile away using waypoint missions. I set the drone to hover when connection was lost then drove to its location where it reconnected and completed the mission.
Adquiri recentemente hoje 14/12/2024 o app para utilizar no DJI MINI 2 SE, porém infelizmente não funciona, ele não conecta o radio ao drone, apenas fica aparecendo a seguinte mensagem na tela “DESCONECTAD” o que devo fazer? Existe alguma forma de fazer funcionar ?
Litchi will not work with the Mini 2 SE, because DJI did not release the SDK necessary for 3rd party developers to create apps for that model.
It is not a Litchi problem.
Mais se não funciona, porque na playstore diz que é compatível?
Isso é um problema, pois adquiri porque na playstore fala que é compatível.
If you read carefully, you will see that its compatible with:
DJI Mini 2
DJI Mini SE
but NOT the Mini 2 SE
I fell for it too. I was looking forward to flying my DJI Mini 2 SE with VR glasses. After much troubleshooting, I unfortunately discovered that compatibility with Mini 2 and Mini SE does not require the functionality of Mini 2 SE. I hope Litchi takes this small step soon.
@glocke Go back and read Post #6.
Thank you for your note. So it’s not Litchi’s fault. Is there any chance that DJI will still release the SDK for the Mini 2 SE?
That model has been out since March 2023, so it’s not likely.
What are the “DJI Fly drones” ?
Are they listed somewhere?
Thanks
We don’t maintain a list but it means all drones that use DJI Fly as their official app.
Also note that this comment is out of date now since the Mini 4 Pro (which uses DJI Fly) can continue a waypoint flight even out of signal range in some countries
