Exportar mision como .CSV
Estoy tratando de exportar mi misión pero me dice que debo hacerlo con una cuenta con licencia verificada y sigo los pasos indicados y aun así no me lo permite
Exactly what steps did you follow?
Have you logged into the Mission Hub using the same account used to log into the Litchi app? If so, in the app settings, select the “Check and sync license” then try again in the Mission Hub.
Sigo estos pasos tal cual, pero aun así me continúa arrojando el mismo mensaje de que debo sincronizar o utilizar una cuenta con licencia valida, he probado creando un nuevo usuario con correo deferente y aun asi sigue el error
You cannot simply create a new email address and expect that to work. You must have a valid account that was used to log into the Litchi app that you purchased. Your first step should be to log into the Litchi app using the credentials that were used when you first purchased it. Once you get the Litchi app to work, then choose “Check and sync license” in the app settings. After that is done, use those same credentials to log into Litchi’s Mission Hub.
Este paso ya lo realicé, y en la app de litchi en el móvil me aparece que se validó correctamente, sin embargo, cuando voy a Missión hub nada que me deja descarga
If you are following the steps that I mentioned and using the original login credentials used after purchasing Litchi, then I do not know why it is not working for you.
Contact Litchi support: support@flylitchi.com
