I used Litchi a few years ago for a very successful Waypoint mission to video a section of our local river, including a section which was out of RC contact at the end which it managed without problem, and came home. For the past few years I have been using Pix4D Capture over a 28 Acre woodland for mapping (with Web Open Drone Map) – very successful until Pix ended support and even somehow prevented me from flying my existing projects! This site stretches my 3 batteries to the limit. Discounted Litchi a year or so ago as its grid missions were restricted to rectangles. Now I find the new Beta can manage polygons - wonderful (not sure whether it copes with concave yet?). I dived in and found a few problems, most of which I have managed to overcome. This is what I have discovered.
1. Litchi will not connect to the drone until I switch off Mobile Data. I have no idea why (but think Pix4D was similar). I now get to site, reboot my Pixel 4a Android phone (to ensure no DJI software or other things running), connect to the drone wi-fi, download my Litchi Mission (screen still showing disconnected) and switch off Mobile Data, at which point Litchi immediately connects to drone.
2. Start Mission, it downloads, but I have never managed to get it to start photographs automatically, so while it flies to first WP I manually set camera to Interval 2 sec and start taking photos. For a short mission that works fine and does a RTH at end.
3. For longer mission, requiring a battery change, I have found that with the new battery a) I have to start photos manually again, and b) have to ensure (manually) that the camera is pointing directly downwards.
4. At ‘RC disconnected’ (which I am testing by switching off the RC, as I know I will require this on my real project mission) it continues to follow WPs until the last one, when it promptly lands (my setting in DJI go is ‘throttle back’ as there is no option to ‘continue’). My solution to this (thanks to a suggestion I read on this forum) is to load my mission prepared on the Beta Hub into the original Hub, and add an extra WP after the finish back near the home point (which should work but is as yet untested).
Update - now tested. Small mission, flies completely. Second flight I switched the RC off and mission was completed to final extra WP (NOT Home, so the extra WP is important!)and then landed, third flight I switch the RC off, and after a while switched it back on again. Light on RC went green (which normally indicates connection) but it took a while longer, 20 secs perhaps,before Litchi showed the green ‘Connected’. It then finished the mission and RTH. All great for future flights.
5. I’m not sure why the WPs are not shown as WPs on the Beta Hub, as they clearly are WPs? Apart from anything else I want a count to try to keep below 99 WPs for the moment, though I think I can see how to cope with more.
I think I am almost ready to try a mission on the 28 acres, once the weather improves! Keep up the good work, developers, thanks.
1 - That’s probably a bug specific to the P3S, don’t think it’s possible to fix that
2 - This is a bug we are working on fixing
3 - a) is because of 2) and b) is also a bug we will try to fix
4 - In the Litchi Hub, if you set the ‘Finish Action’ to ‘RTH’ the drone should RTH at the end, regardless if you have connection to the drone or not
5 - In the Litchi Hub, you can hover (using a mouse) the ‘Distance’ at the top of the flight settings to see the total number of waypoints
1 Happy with that. I realise P3S is at the extreme of ancient.
2 and 3 Thanks. Can cope with 2a).
4 Not my experience. I have RTH set at Finish which works normally, but twice now with RC off it has just landed at the Finish WP (the first time just 1m away from a road!). 5 Which is why I am desperate to create an extra last WP near Home - this workaround has worked well but would be easier if the WPs showed as WPs in the Area Mission on the new Beta.
Thanks again for the help, much appreciated. Happy to do any further tests if required. R
We don’t recommend using the new and old Hub together. It is likely to cause issues as the old Hub won’t understand any of the new flight properties introduced in the new Hub.
If the finish action is set to RTH, and it lands at the end, it could be that the drone is close to the home point (within 20m or so). Other than that, it should not land at the end, provided there is no bug in the P3S DJI firmware.
Thanks, I’ll do more testing with the new Hub (and avoid the old hub!) once the weather improves. Your message finishes with the killer ‘provided there is no bug in the P3S DJI firmware’! Since they stopped supporting P3S several years ago, I wouldn’t bet on that (but can’t expect you and Litchi to solve what might be DJI problems.
Since I can set timed (not distance) intervals manually in Litchi (on my previous flights) the P3S must have that feature somehow, and I’m quite happy to set a timed interval (based on speed) and for mapping getting too many photos is not a problem.
I am disappointed (sorry) that you now are providing a WP at every photo point. My major project involves over 1800 photos, and with the 99 WP limit, that means 18 stops to load more WPs . . . and they will all have to be within RC range. Is it possible for me to tell Litchi that I don’t want photos, and just have what I have at the moment, the basic flight/turn WPs?
(P.S. I’m not wure how Pix4Dcapture managed all this - I couldn’t delve into details, just loaded and it ran.)
Thanks again for your continued support/development.
You can now choose your preferred method using the new ‘Photo Capture Mode’ setting, see changelog in this thread [OPEN BETA] Litchi Hub - #340 by vico
Alternatively you can also set the Capture Mode to ‘Manual’ then remember to start the capture manually.
The Phantom 3 series’s onboard waypoint engine (aka DJI engine) does not natively support interval capture. While Litchi technically could start an interval capture at the start of the flight (simulating you pressing the take photo button while in Interval photo mode), currently that’s also not supported. It was never implemented as newer drone models support it either natively or via the Litchi waypoint engine (also not supported for P3 series).
Looks great Vico, many thanks for spending so much time and effort for a minority of users (me?) and a very old model of P3S drone. Many organisations would just say (sorry that’s too old . . ). Weather not conducive to test flights at the moment in the UK, but I will try as soon as things settle down a bit.
