For some weird reason my taskbar cannot be accessed when I run Litchi. I’ve tried everything I could but nothing helps so I’m wondering it there is an exit function I’m missing somewhere in the app. It would make life so much easier for me. FYI I’m using an LG K61 phone.
Swipe the screen from the physical bottom up.
Yip tried that as it usually works, but not in this case. I’ve changed the setting to not hide the taskbar but Litchi seems to ignore that. I’ve figured out a workaround but it is very tedious. I go to settings and then select one of the external links at the bottom i.e. privacy policy, which exits the app to open a webpage. This gives me back control over the taskbar.
Try restarting your phone, it could be just a glitch.
Tried that as well. Also tried to reinstall Litchi but I think it is some weird situation where Litchi goes into immersive mode on this phone, which is dedicated to this task, and refuse to let go.
Hi Anton,
An exit button will be added in the settings for this rare case affecting some mobile devices in the next update.
Thank you so much for this. I understand that having an exit button is not standard mobile design, but it will most certainly make my life much easier.
