Hi,
I am trying to import KML to Mission Hub, I have done the same process successfully in the past and the file looks good in Google Earth, but I am getting “Error: failed parsing kml file” when importing today. It is a simple series of points, KMZ was created in GIS software, opened in Google Earth and saved as KML.
Here is a sample file:
https://carvercounty-my.sharepoint.com/:u:/g/personal/pclark_carvercountymn_gov/EccrMW4qf5BOozQ5PXyjORUBwj2zVqrsvf1PbnMRE1SDSw?e=iX51jY
Thanks for the help!
Your KML document is named “E1”. It also contains a folder named “E1”. Inside that folder are a series of Placemarks with Points. Each Placemark also contains embedded HTML code.
When imported into Google Earth Pro, expand the top-level “E1” to reveal the folder named “E1”. Right-click on the “E1” Folder and choose “Save Place As…”. Once saved as a KML file, it will be importable into Litchi.
Apparently, Litchi is unable to traverse through folders in the KML file.
That did it! Thank you very much.
