I’m configuring my Litchi missions so that the DJI Air 2S does not take photos from WP1 until it aligns at the corner waypoint where the photo sequence should start. However, when I review the mission in Litchi Hub, the drone still makes turns or rotations at each waypoint that is set to “no photo”.
Could someone please help me adjust the settings so the drone just passes smoothly through those points without stopping or rotating, until it reaches the waypoint where it should begin taking pictures?
Good morning, friends. I think I didn’t phrase my question correctly — I’m not asking for help planning my flights, but rather for your help reviewing them and letting me know where I made mistakes in the planning.
What I did differently was that I configured the mission in Litchi so the drone wouldn’t take photos at the first waypoints, but before reaching the area where it should start taking photos, it begins to make several turns at each waypoint. Thank you in advance for your cooperation.
In settings you need to off curves, on the mission screen you will see a blue line which is your flight path, once curves are turned you should be good to go, this happened to me once before and now works fine.
