I recently changed the screen resolution of my Sony Xperia XZ Premium to 4K (size 2160×3840 and density 820). The problem is that when I’m in VR mode on Litchi, the double image of the lens is very reduced, making it impossible to use it with the glasses. Does anyone know how to solve it? Thanks.
I managed, through the XDA Forum at this link: “https://xdaforums.com/m/xperiaxz.10669465/”, to make progress:
"Okay - Solved this. Here is how to configure 4k screen for any VR viewer.
- Go to: https + : + //: + wwgc + firebaseapp + .com (Sorry can’t post urls as a newbie user.)
- Follow the instructions and correct the view so that it looks perfect on your headset (all the lines are straight etc.)
- Then set the “Screen to lens distance” and “Inter-lens distance (mm)” to exactly the double it would have been normally. Screen to lens distance: 41 → 82 and Inter-lens distance 60 → 120. - For gear VR Distortion coefficient k1 is 0.050 and k2 0.2.
- Create the QR code and scan it with any 3rd part QR code reader into your cardboard app. (cardboards own qr code reader gives a lot of errors, but this works)
Here is a working profile for Sony xperia XZ that is set to 4k all the time with abd command. Optimized for Samsung Gear VR ."
Therefore, When I double the required measurements during the VR headset setup for the XZ Premium, it solves the problem for 4K screen for the Cardboard APP or other that follow the same standard, but not for the Litchi.
If anyone can help me, I would be very grateful. grateful.
