Rene1
August 31, 2026, 6:21am
1
[fixed ] I made a flight in the beta Hub yesterday, exported the .kml to my downloads.
Then in the Litch app (v5.0.2-g) I try to import it but I get this message: File import error, the imported file is not a valid Litchi flight.
Did download the .bin file earlier and got a message there that the gimple wasn’t working properly.
But i learned the .bin isn’t what I needed.. It did get me further then the .kml file as I got the flight on screen.
I’m also using the GL100A RC, the drone in a MM1A
The app does recognize and let me fly the drone without waypoints.
Rene1
August 31, 2026, 10:22am
2
So I found out that I don’t have to load the files for it to work.
It flew the flight, did have to manually alter the gimbal pitch to -85 as that was the next issue.
I wonder if the function to export the .kml file and manually import it again will be made available.
The reason it didn’t work initially is that the wifi was not syncing the account as it was hooked to the RC.
Did make the flight plan on a different device..
vico
August 31, 2026, 12:33pm
3
KML import is not currently supported other than for map overlays. We may add support in the future but in general we would advise planning directly on Litchi Hub
