Hello.
I want to fly in FOLLOW mode with DJI mini 2.
Which of “CNE”, “NORMAL”, and “SPORT” should be selected for the transmitter flight mode switch?
The RC should be in Normal mode
VICO, thank you for your answer.
I chose “NORMAL” with the same judgment. After various settings, I started flying, but it only hovered in the air and did not follow my movements. What’s wrong?
Did you enable "Horizontal Movements’ ?
Did you move with a speed of at least 1 m/s (3.6 km/h) ?
Maybe the gps accuracy is out of range
TriBar, thank you for your response.
“Horizontal movement” is effective, and the movement speed is 1m / s or less.
GPS sensitivity is also sufficient.
DJI FLY is off, should it be on?
bpa, thank you for your response.
GPS sensitivity is sufficient. (12 or more)
You can see at least 20 satellites, this does not apply to the “gps accuracy” parameter. Be careful.
It turned out that the FOLLOW mode does not start when the GPS accuracy display color is “red”.
Until now, I was not aware of the display color.
I will try it next time. Thank you very much.
I told you about it.
Put in the settings 15-20m and it will work. 10m is too short
OK.
