Sunday March 20
First ever flight with DJI Mini 2 and Litchi.
I made a short mission to fly in the park to try out the waypoints.
Worked well until waypoint 10 and then the drone went berserk because
of failing signal strength.
The signals were blocked at that point by the large building in the centre of the park.
I pressed the return to home button, but of course there was no signal getting to the drone,
I had to run 80 metres across the field to get the return to home signal connected again.
Watch the signal strength indicators in the top right of the screen, even at 30% signal the
drone gives up.
When the signals are back at 100 % the drone does not pick that up and does not continue the mission.
Interesting that the drone stops at every waypoint that does not include an arc ( waypoint 6 )
even if the waypoint is in the centre of a straight line.
I later flew a straight line mission with out any arcs, and the drone stops at every single waypoint.
